I have a potterton Netaheat Profile boiler circa 1989, gravity fed how water and pumped CH, flushed and treated in last 12 months.
The safety cutout trips intermittently (can go for days without tripping, others it will trip 2 or 3 times) on the boiler but I suspect it may be functioning correctly and it may be the boiler temperature cutout at fault. The reason for this thinking is that also intermittently, I can see the CH thermostat calling for boiler (digital therm with display), boiler comes on and lights but shuts down after a few seconds and the CH therm is still calling for the boiler. My thinking being if the boiler temp control is intermittently faulty to this degree at this end of the scale (heat exchanger not hot), it may also be intermittently failing at the other end of the scale and failing to shut the boiler down and hence the subsequent safety trip.
Any advice on testing this out or even wether parts are available or even capable of being replaced (corgi or otherwise) ? I'm not familiar with the mechanisms involved here as it is an area I've not been involved with before, but I'm guessing there is a thermocouple or similar involved here. Any advice or information welcome.
