Original fault was the machine had stopped halfway through a wash cycle. I cleaned the not-so-dirty filter and then set it going again, but then the programmer started to spin round without stopping anywhere. Thinking it was the programmer (it had got a bit "loose" in its movement), I ordered another one, but now it spins round and stops on "3". I took the load out and it now spins round and stops on the drain?
Should I drain and start all over again? Or is the spinning indicative of a deeper fault. The neon light does not flash at all, just stays on while the power switch is on. Help!
