one cold radiator
4 Mar 2005
i have one cold rad upstairs all others ok.
i bled the rad, air and then water came out and i closed the bleed valve, the rad appeared ok after and heated up,but later went cold again, tried to bleed again but no air or water came out. the inlet valve and outlet valve are both hot. the rad is only hot where the valves join. Would appreciate your help.
