Pressurised shower - p shaped bath slowly filling
26 Nov 2007
People,
I have a Pressurised shower running at about 3 bar with a flow rate of arround 13 litres per minute.
When using the shower (which is above a p shaped bath) the shower slowly fills. It begins to fill after around 20 seconds and continues to fill throughout the shower. It then seems to drain slowly
Should this happen?
Cheers
Need Help21
No.partial blockage somewhere or bad fall on the drainage.first port of call would be to clean the shower trap itself.
I have cleaned the trap. I am convinced there is a buildup of cr*p further down the pipework. Can you suggest a decent type of cleaner. I have a rodding point around 1.25 metres from the suspected blocked pipe
Many thanks, Please advise if you have used the above mentioned product
excellent thanks, and one final question, does it appear to remove sludge that is around the complete internal circumference of the pipe ie. like clogged up arteries?!?!? The reason I ask, is I do not think I have a blocked trap. The block appears to be an old 1m length of pipe just prior to entering an internal stack
