DIYnot
Local | Network
   DIYnot > Forums
Local | Network
2003 Ford Fiesta 1.4 battery light is on
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
alan666
from United Kingdom
PostPosted: Wed Apr 14, 2010 7:22 pm Reply with quote
The battery light on a 1.4 2003 Fiesta is on constantly. When I put the battery on a battery charger/conditioner, it reported the battery was poor or sulphated and couldn't be recovered so I replaced it but the battery light is still on. I have checked voltages and the alternator was not charging so I removed the smart charge plug and it charges at 14v. I have read elsewhere that pin 3 on the Focus smart charger plug should be at the same voltage as the battery as it is a reference voltage. Don't know if it is the same on the Fiesta so I checked, but I wasn't sure which was pin 1 and which pin 3. One has around 4v the other 8v so neither has 12v. Any ideas what else I could check?
Back to top
 Alert Moderators
^neo^
from United Kingdom
Thanked: 43 times
PostPosted: Thu Apr 15, 2010 8:30 am Reply with quote
sounds like the voltage regulator in the alt has died.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 423 times
PostPosted: Thu Apr 15, 2010 3:57 pm Reply with quote
Is it a silver calcium type battery? What type did you replace it with?
Back to top
 Alert Moderators
diydazzler
from United Kingdom
Thanked: 1 time
PostPosted: Thu Apr 15, 2010 4:06 pm Reply with quote
Put a volt meter across the battery with the engine running and you should see around 14 volts.
If its less ie 12v then the alternator needs looking at
Back to top
 Alert Moderators
alan666
from United Kingdom
PostPosted: Thu Apr 15, 2010 7:11 pm Reply with quote
It is an AC Delco Calcium battery. With the 3 pin plug disconnected from the alternator there is over 14v measured accross the battery so the alternator is charging as it should but when the plug is reconnected, it stops charging. So the problem is somewhere with the smart charging circuit.
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2593 times
PostPosted: Thu Apr 15, 2010 7:35 pm Reply with quote
Ye gods and this is what Ford call progress.....
They developed smart charging to cope with the new calcium batteries. This effectively boosted the charging voltage to around 15v - but it was controlled by the cars ECU - not by the alternator.
Removing the smart charge plug allows the alternator voltage regulator to take over and the battery will still be charged - although the battery light may still be on.
Check the wiring condition as it leaves the smart charge plug - if one conductor is broken, frayed or burnt you get your symptoms.
(I got this from a Transit TSB by the way...it may apply to yours).
Hope this helps!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
ford fiesta 2003 diesel injector seal replacement 8 5520 Wed Feb 28, 2007 12:39 pm
Renault Clio 1.2 2003 Toxic fume warning light 17 55380 Sun Aug 10, 2008 6:55 am
VW POLO 2003 1998 cc petrol Engine Light On 11 380 Mon Sep 24, 2012 5:54 pm
HELP! Engine Management light on Corsa C 1.0 12v 2003 7 22800 Tue Feb 16, 2010 10:27 pm
VW POLO 2003 1198 CC Engine Light 5 340 Mon May 06, 2013 4:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
