DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Boiler thermostat faulty - calibration problem?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
StuartBradwall
from United Kingdom
PostPosted: Fri Apr 16, 2010 9:13 pm Reply with quote
Hi, I think my boiler thermostat is faulty (called out of calibration)? What happens is the heating takes ages to heat up now, the system is clean though the water is not sludged up at all.
How can I check for the boiler thermostat being the cause.
The hot water cylinder water seems OK though (maube it is less noticeable than the radiators)
The boiler is old, Potterton: Flamingo II RS50.
The pump is fine I have only had it fitted under a year ago, it is Grundofs 15-50. We have a 3 bed house.
The probelm has been this way for about 4 days now.
Back to top
 Alert Moderators
transam
from United Kingdom
Thanked: 1517 times
PostPosted: Fri Apr 16, 2010 10:37 pm Reply with quote
It might pay u to get an rgi to check your burner /gas pressure at the boiler ?????????
Back to top
 Alert Moderators
StuartBradwall
from United Kingdom
PostPosted: Fri Apr 16, 2010 10:49 pm Reply with quote
I haven't had the pressure adjusted on the gas valve though so it should be the same as what it always has been.
Do you think the injector could be a bit blocked up? What would cause this?
Would you say the boiler stat is probably not the cause then?
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Sat Apr 17, 2010 11:47 am Reply with quote
But there could be a problem with the incoming supply which needs checked by a rgi.
Other than that it is a circulation problem.
Back to top
 Alert Moderators
stanboy
from United Kingdom
Thanked: 1 time
PostPosted: Tue Apr 20, 2010 2:37 pm Reply with quote
a quick check on your gas supply pressue depending on you having a gashob is. Put all your gas rings and cooker on full and note if the flames go down when you get the bioler to fire up.If they do you can assume your gas pressure is low, if they dont its ok. If you havent got a cooker ignore this,
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
calibration of analysers 3 340 Fri Apr 04, 2008 6:03 pm
FGA calibration 13 260 Wed Oct 01, 2014 6:05 am
gas analyser calibration costs 3 640 Sun Nov 04, 2007 10:55 am
BAXI BBU HE15 Calibration Controls 4 100 Sat Feb 22, 2014 6:39 pm
Gas Flue Analyser calibration 5 620 Sat Jun 26, 2010 5:50 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
