Trying to find tubular privacy bolt with 44mm backset
5 Dec 2008
Hampshire
Does anyone know where I can find a tubular (mortice style) bolt latch with a 44mm backset, to take a 5mm spindle?
I have been searching all over without success. I've found latches for door handles in this size, but they'd be no good for a bolt would they, as they are sprung to hold the latch out.
This is what I am looking for but I need the shorter backset:
http://www.diy.com/diy/jsp/bq/nav.j...ndid=9277051&ecamp=trf-005&CAWELAID=266934556
(As you can see from the comment on that page someone else has had the same problem I have!)
Any help much appreciated...
nearest i can find is 57mm backset. the only 44mm will be a mortice lock.
i will enquire tomorrow when my ironmongery supplier opens. if there is one available he will know..
after speaking to my "oracle" there is no such thing.. you will have to either chop in a lock or have a deeper back set 57mm minimum. you have no other choice. regards..
