Im baffled with this drop in pressure
15 Mar 2006
Tyne and Wear
This is totally baffling me
Combi boiler
i top the boiler up (ch) to 1 bar, after around 24 hours the pressure drops to zero (heating running throughout via room stat)
I then top boiler up (ch) to 2 bar turn heating completely off for 24 hours and no loss in pressure
During this time dhw is being used
I check everywhere for leaks no sign what so ever pipework/prv/rads under boiler absolutely nothing at all
Scratching my head with this one
Sound like the pressure vessel is knackered. Feel the prv pipe see if it gets warm or find where it terminates outside i bet it is wet.
Downstairs too? you need to let the system go cold as it will be evaporating when hot
Also try isolating the boiler over night and see if it drops - if it does you know the leak is in there!
I let the system go cold overnight, then topped it to the 2 bar, 24 hours later still sittin at 2 bar,
both upstairs and down all pipework runs under beams
Just to 100% take the prv out of the equation stick a ballon over the end of the pipe while you are running the heating........
ive done that and not a drop in sight
Could be the plate HX is pin holed.
Does the gauge go up and down if you open and close a hot tap
I dont think you tried this for long enough (34mins between suggestion and your result post). try it again, for 24 hours, from cold @ 1bar, and watch the pressure gauge as the system heats up.
