flashing lights on hotpoint aquarius wt540
19 Apr 2010
Fife
i have just switched on the washing machine and the start button is flashing and also the wash enhanced and reduced creases buttons are flashing ( 1 and 2)
the machine was working fine until it was switched of at the mains
can you help ?
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
it looks like communication error acording to the fault listed can i rectify this and how ?
thanks
john
remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work recon pcb needed from here.http://www.emwelec.co.uk/
Remove the lid and the plug for the consol panel is top right hand corner it's got about 5 wires on it.
Hi, I have a similar problem, but just light no. 3 flashing part way through the washing cycle. One of the previous responses said it could be a motor problem, but in our case the motor seems to be ok (at least it is working for some of the program). Any ideas anyone?
Hi!
I have an Aquarius WT540 and i have a similar problem. In my case ALL THE LIGHTS are flashing when turned on at the mains and it can't be turned off using the on/off button. What should I do?
Russ C
C17 cap on pcb loads of posts about it.
Hi, where would I find the PCB with capacitor C17 as I am having error code F15 and can only find the console/display PCB which only has surface mount parts and no legend/top silk?
