Yep, you can spend silly money on speaker cable and interconnects. Not worth it for the average Argos hi fi though
I'm currently running stuff that costs £35 quid a metre which I think sounds better than most I have Tried. I have run Mains cable in the past and its not bad. I have also demoed stuff up to about £150 a metre and couldnt hear the difference. My units are not that top end though, I couldnt hear much difference between the mid raneg and top end stuff to arrent the tripling of cost
Biggest difference on my system was putting a choke and smoothing capaciter into the mains plug and cleaning up the mains a bit. Cost about £3!!!!
Basically if you are running the bell wire that come with your Hi-fi, then mains cable is a really cheap way to upgrade. Mind you, if you hi-fi come with speaker wire it may not be good enough to be improved!!
