Type of valves??
23 Feb 2010
Clackmannanshire
HI,
Wonder if someone could identify the types of valves/part numbers in pics below. they are leaking and i need to get some new ones. Would also be grateful if you could let me know where i could source thes from too, so i can get a handle on the price.
Many thanks
Looks like an Icos HE and these valves sould be readily available to order from a local spares merchant or direct from Ideal.You need to give the exact model ie HE 24 etc.Data badge is behind front cover.Expect to pay £15/20 per valve.Easy DIY install.The RH valve is almost closed off?
Hi, cheers Gasman.
Right, im always up for a challenge., i think i will take this on if you think its straight forward
Its an HE24. ICOS reckoned i needed to by a "hardware pack" which include the 2 isolating valves i require, is this correct? they also said they dont have any!
Any ideas where i might get 1No. isolating valve C/W pressure gauge, and 1No. isolation valve C/W drain.
And yes, that was half closed. no idea why! wasnt us who touced it, perhaps the gas enginieer who serviced the boiler in 2008.
Are you sure the leak is from the valves. On picture No2 from the verdigri staining it looks like the compression joint is the source of the leak.
