Radiator cold - cutting into pipe question
24 Apr 2010
Bath
Hi all
I have a radiator that is not heating up, the other are all fine. I only have my heating on for a few hours in the earlymorning so it's not too bad at the moment but I'd like to fix it.
After reading this forum I have found sludge in the flow pipe to the cold radiator (the magnet stuck to it quite strongly).
So I want to drain down the system (it is vented) and cut out and re-pipe the sludged part.
My question is this:
If I drain down the system from the draincock on the lowest rad, and cut into the pipe, will I get a flood of water - will the sludge block the flow from that part? Or will most of it drain. I just want to be sure before I do it.
Thanks for your advice
Jason
Turn the radiator valves off at both ends of the rad then remove the radiator taking care not to spill the water on the carpets. Flush out the rad with a hose pipe to clean it out. Put a hose on the radiator valve, open the valve and flush the pipe. Do the same on the other valve and pipe. Fit the rad back, fill and vent. Then try the system this usually clears the sludge.
Hi, thanks for helping
One question: why do I need to put the hose on the radiator valve, can I not just open them into a bucket to flush them?
Yes but it is better to have a hose fitted then you can open the valve fully and let it run out faster and longer to move the sludge out of the pipe.
Ok thanks. I don't knwo oif my hose will fit the valve though, it's a standa
rd 1/2 inch hose. Will emptying into a bucket shift it? Thanks mate for your help
ok will do, hopefully this'll shift it. One last point if I may: I'll drain the rad first, then remove out and put loads of old towels down, any tips to stop any sludge spillage onto the carpet when removing a rad?!!! :oops:
It may be safer to roll the carpet back from under the radiator so if you spill and black water it is on the floor not the carpet. Block up the radiator holes so you don't spill on the way out :oops:
