DIYnot
Local | Network
   DIYnot > Forums
Local | Network
difference between 3 port & mid position valves
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
angelf
from United Kingdom
PostPosted: Mon Apr 26, 2010 12:07 pm Reply with quote
what is the difference between a 3 port valve & a mid position motorised valve?
Can one be replaced with the other?
If not why not?
Cheers
Back to top
 Alert Moderators
Mr Smyth
from United Kingdom
Thanked: 25 times
PostPosted: Mon Apr 26, 2010 12:24 pm Reply with quote
A 3-Port valve lets you select HW or Htg whereas a mid position valve lets you select HW, Htg or both HW and Htg.
Yes you can change a 3-Port to a mid position valve but there will be some simple changes to your wiring.
Hope this helps
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 696 times
PostPosted: Mon Apr 26, 2010 12:32 pm Reply with quote
Both of these have "3 Ports" ie inlet port and hw and heating outlet ports.
A mid position valve is able to allow water to flow to HW only,CH only and to both at once by holding the valve in the Mid Position,These valves normally have 5 wires. A 3 port diverter normally has 3 wires and can only supply CH on its own or HW on its own but not both together.These valves as such are interchangeable with some wiring alterations.
Back to top
 Alert Moderators
angelf
from United Kingdom
PostPosted: Mon Apr 26, 2010 7:31 pm Reply with quote
thanks Mr Smyth & 45 year gas man
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Difference between Part 1 and part 11 ball valves? 12 2420 Sat Feb 03, 2007 2:31 pm
CMT921 - CMT927 Difference? 13 720 Sat Feb 06, 2010 12:45 pm
radiators-is ther any difference in quality or all the same. 4 440 Wed Jul 28, 2010 9:19 pm
Difference in quality of TRVs 17 1940 Tue Aug 31, 2010 9:32 pm
Whats The Difference Between Type A & B Drain Cocks? 3 500 Sun Jul 11, 2010 7:48 pm
DIYnot
