Hi all, i know, i know another decking question But search did not bring up anything on what i need.
Ok, my decking area is fairly large and on a slop so will be part raised.
The dimensions of the area is 4.7 M wide by 6.6 long.
I'll be using 4.8M joists (14.5 x 4.5cm) and 2.4 M boards. The board will be going across the width of the 4.7 so 2 boards will complete a length with hardly any wastage. And i want to step the decking so it looks nicer than having one join in the middle.
Now i have read that centers of the joist should be 40cm apart, this is fine if i were to do 2 full boards across as each ends hits a joist, but as i want to step it, the half decking board (1.2m) will not hit a joist.
Now if i do 60cm centers everything will work out great, but is this to wide? I will be putting in Noggins every 60cm from the same joist material
Is this ok do you think?
Thanks for any help
Thanks for any help
