DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wireless Problems with Netgear DG834GT router
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Hardware
Author Message
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Sun May 02, 2010 8:29 pm Reply with quote
Hi, I am trying to set up my Samsung N130 netbook to connect wirelessly to my netgear DG834GT router (SKY) but failing miserably!
It works fine with ethernet cable but not without.
The notebook "sees" my router when searching but wont connect.
I've tried resetting the router, typing the correct network key at various security settings and also disabling security altogether on the netgear settings page but to no avail.
Does anyone have any ideas?
Back to top
 Alert Moderators
wanleg
from United Kingdom
Thanked: 14 times
PostPosted: Mon May 03, 2010 10:39 pm Reply with quote
Any other machine connected via wireless or is this the first ?
Any MAC address filtering turned on on the router ?
Back to top
The following user says thank you to wanleg for this useful post:
BigJon (13 May 2010)
 Alert Moderators
imamartian
from United Kingdom
Thanked: 54 times
PostPosted: Mon May 03, 2010 11:03 pm Reply with quote
I have had loads of problems with my DG834GT router . Have had it about a year... but still struggle to connect sometimes. Best thing to do seems to be to log on to the router... put http://192.168.0.1 into the browser field (no WWW!), and then put in your password - Admin/password... go to connection status (at the bottom) and disconnect and then connect.... it usually says LCP Down for me!!!
If you do ever get online, download the latest firmware..... from the Netgear website.
And then you can also power down your router (for a good 10 seonds) and reboot!
Good luck
Back to top
The following user says thank you to imamartian for this useful post:
 Alert Moderators
big-all
from United Kingdom
Thanked: 965 times
PostPosted: Tue May 04, 2010 8:30 am Reply with quote
have you put the key in!!
mines is 50 40 30 20 10 and i believe its factory default !!
Back to top
The following user says thank you to big-all for this useful post:
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Thu May 13, 2010 6:12 pm Reply with quote
Hi, I managed to get it going eventually after messing with various settings (dont ask me what ones lol).
Been away so not been able to reply.
Thanks for your info i'll see about getting latest firmware.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3608 times
PostPosted: Sat May 29, 2010 12:58 pm Reply with quote
I have exactly the same equipment and problem as the OP.
The NC130 "sees" the LAN but will not communicate through it.
Where do I go to check its settings and perhaps enter the Key as listed above?
Tony
Back to top
The following user says thank you to Agile for this useful post:
disinfo (30 May 2010)
 Alert Moderators
big-all
from United Kingdom
Thanked: 965 times
PostPosted: Sat May 29, 2010 1:11 pm Reply with quote
http://192.168.0.1
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3608 times
PostPosted: Sat May 29, 2010 6:22 pm Reply with quote
Whewn I try that in my main computer it comes up as unknown!
Tony
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 965 times
PostPosted: Sat May 29, 2010 6:36 pm Reply with quote
Tony
try it in the search box without the http
i get this and a box for user name then password
site says:
A user name and password are being requested by http://192.168.0.1. The "NETGEAR DG834PN "
Back to top
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Sat May 29, 2010 10:37 pm Reply with quote
The address Big-all wrote is correct,
Did you have any luck?
If you did get to the point where your entering the wep key I found it had to be in capital letters in order for the connection to be accepted.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3608 times
PostPosted: Sat May 29, 2010 10:47 pm Reply with quote
It will not display, saying "internal server error".
AOL can be a little different!
But when I try accessing that site from the mobile through "3" internet, it will not load either giving server error.
Tony
Back to top
 Alert Moderators
BigJon
from United Kingdom
Thanked: 25 times
PostPosted: Sun May 30, 2010 4:52 pm Reply with quote
What ISP are you with?
Does your router need to have the AOL firmware on it in order for it to work on that network?
Is there any information on the base of it about accessing the settings.
My sky one doesn't give any information about this but I put a Virgin router in for my sister yesterday and it had all the info on the base of it.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3608 times
PostPosted: Mon May 31, 2010 12:44 pm Reply with quote
I am with AOL.
The router was supplied by AOL ( as TalkTalk ).
There is nothing to help on the base of the router.
The 5040302010 does not work.
If I save up and go to Starbucks, what "Key" do I need in the phone WLAN setting.
Why do others just seem to turn on and connect?
A friend did have to call an expect to help her connect her computer on a wired basis to AOL.
Tony
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Mon May 31, 2010 1:21 pm Reply with quote
No you don't - you need to start a new topic.
You go to the new topic.
Agile wrote:
I am with AOL.
That's two fundamental mistakes you've made.
Only Starbucks will know the answer to that question. Do you actually understand the question that you're asking?
Because they're using a sensible ISP and sensible equipment.
A friend?! Don't be silly.
Back to top
 Alert Moderators
virgin_paul
from United Kingdom
PostPosted: Tue Jun 08, 2010 7:42 am Reply with quote
A large number of AOL (talktalk) supplied routers must be connected to a pc via network cable and set up using the instl. cd BEFORE the wi-fi will work. The set up must be done via lan connection - it will not work via wi-fi like a shop bought one can.
I have lost count of the amount of friends/colleagues who have changed to talktalk recently and decided to replace their own routers to the new talktalk one - then found the same problem!
Paul
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Hardware All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Trying to set Netgear DG834GT up. CHAP failed???? 9 1360 Wed Jan 09, 2008 11:23 pm
Netgear wireless router connection problems 4 960 Wed Jan 17, 2007 6:16 pm
netgear firewall adsl wireless router 2 920 Sun Jan 23, 2005 3:52 pm
Netgear router-what type of connection does the aerial have? 12 1460 Tue May 20, 2008 6:58 pm
Netgear router keeps changing LAN IPs 15 860 Wed May 11, 2011 9:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
