M
marsaday
I have to fit a 75mm joist into a steel channel x2. Do i need to get this shaped up in order for it to be a good fit ?
Also how do i fit it in place. I will be bolting 2 channels to a truss. So do i do it all at the same time (difficult i reckon) or do i set the channels onto the truss with the large M12 bolts poking through. I then measure where the holes need to be on the joist and drill them and then slide them onto the bolts.
The query i have with this is can i drill a wider hole into the joists to make locating them easier. the bolts are 12mm and i would like to drill 20mm. I will be using 75mm timber plate connector to stiffen everything up.
can anyone see a problem with this solution or do they have a better solution?
