garrymum
Joined: 16 Sep 2004 Posts: 638 Location: Leeds, United Kingdom Thanked: 4 times
Posted: Mon May 10, 2010 7:50 pm |
Hi guys
I am trying to measure where I can drill from the loft so that I can feed a co-ax cable down the space between the plasterboard and the blockwork. I have a reference point in the loft as the coax from the outside aerial enters the loft from the gable end.
I know the bricks are 100mm deep. What I need to know is what depth is the cavity and the blockwork. If I can find the total measurement of bricks + cavity + blockwork, I can roughly get a distance from the total width to where the aerial cable enters the house on the outside. Then when in the loft, I can measure back from the cable entry. This hopefully will give me a point to drill. Hoping to then feed a coax cable down the hole between the plasterboard and the blockwork.
I had a look in the loft and the plasterboard ceiling butts up to a header plate (approx 4" wide). Will this be somewhere close to the point I need to drill?
I am trying to cause as little damage as possible to the bedroom.
Any suggestions?
Thanks. |
stuart45
Joined: 13 Sep 2008 Posts: 1440 Location: Somerset, United Kingdom Thanked: 125 times
Posted: Mon May 10, 2010 8:26 pm |
How old is your house? |
garrymum
Posted: Mon May 10, 2010 8:41 pm |
Sorry, I was gong to add that but forgot after all my typing.
It was built in 2001. Brick built detached, think it was built by McAlpine. |
stuart45
Posted: Mon May 10, 2010 9:29 pm |
Chances are that the cavity is 100mm, and internal block 100mm. This is not definite though. You could measure the thickness at the reveals. |
garrymum
Posted: Mon May 10, 2010 9:45 pm |
| stuart45 wrote: | | Chances are that the cavity is 100mm, and internal block 100mm. This is not definite though. You could measure the thickness at the reveals. |
Thanks Stuart.
I always have to find the most difficult route at times!  |
