DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
washing machine rinse water soapy/dirty
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
butterbean
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 11, 2005 8:44 pm    Post Subject:
Reply with quote Thanks
For a while I have been noticing that my washing is not being rinsed properly. Residue is left in drum and clothing still has soap in. Have tried everything, less powder, different powder, even a new washing machine!! The pipe runs from the machine and directly into the side of the toilet, there is exit to outside drain. Any ideas what could be causing this? The machine being faulty has been ruled out now.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
newboy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 11, 2005 9:05 pm    Post Subject:
Sounds like a blocked / partially blocked waste pipe
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 11, 2005 11:57 pm    Post Subject:
I'm inclined to agree with newboy. You'll just have to sit through a whole wash and rinse cycle and ensure that the machine empties completely between fills. If it does empty properly, here's another test. During the wash cycle open the soap tray and see if the soap's all gone. If your inlet flow is too weak it may not be taking all the soap into the drum.
This is a long shot but is the outside drain gully higher than the bottom of the machine. I know that's not very likely but you never know. If it is and if the end of the machine drain is submerged, dirty water will syphon back into the machine when the pump stops.
Another thought, and please accept my apologies if it's a stupid question. It would appear that you're using cold fill only. Are you putting the soap in the right half of the tray?
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Sat Mar 12, 2005 1:21 am    Post Subject:
check that the water input (blue) hose is delivering plenty of water by tuning off the valve then disconecting it and turning on the valve. I've seen the self drilling types corrode up.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sat Mar 12, 2005 12:09 pm    Post Subject:
why is this in appliances when its obviously a plumbing problem ??????? icon_rolleyes.gif
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
butterbean
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 12, 2005 7:08 pm    Post Subject:
I originally posted it in plumbing and central heating - but it was moved to applicances.
Could it be that the outlet pipe of the washer is connected to the sink waste? should it just go directly outside ideally ?
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sat Mar 12, 2005 7:24 pm    Post Subject:
dig wasnt at you mate it was at the twit that
1 moved the post
2 didnt bother telling anybody why (common courtesy)
wuold think the waste is partially blocked somewhere as my collegues have told you
only way realistically is to dismantle the lot and check it
not a pleaseant job but look on the bright side it could be the loo
Moderator,
icon_redface.gif This was a difficult one and I felt if anybody else has the same problem with their washing machine they will look in the Appliances forum as it was reported a washing machine problem to start with.
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 13, 2005 10:38 am    Post Subject:
If you connect your washer drain into the sink waste the wrong way, or even the right way if the sink waste has a partial blockage, dirty water from the sink will find its way into your washer. You can test this easily enough. Fill the sink and pull the plug a few times. Is the washer filling up?
____________________
moderator
post locked (over 1 month old)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hoover Softwave-still soapy after wash. 5 700 Sun May 13, 2007 9:00 pm
hotpoint WMA 74 water gushing from draw when rinse and spin 3 180 Tue Feb 17, 2009 8:46 am
washing machine does not rinse properly 2 2320 Thu Jul 05, 2007 9:43 am
Washing machine won't rinse 15 1900 Sat Mar 27, 2004 11:48 am
Whirlpool washing machine rinse aid problem 3 920 Tue May 08, 2007 11:23 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
