DIYnot
Local | Network
   DIYnot > Forums
Local | Network
removing olive issue
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
vik2001
from United Kingdom
Thanked: 2 times
PostPosted: Mon May 17, 2010 8:13 am Reply with quote
i was changing a radiator valve over weekend. i removed the original olive, but couldnt fit the new olive and nut on properly. whats happened is the original olive had made a indent around the pipe, probably from being on so tight...
what can i do?? i dont have enough play in the pipe to cut it back and put a new olive on,.
Back to top
 Alert Moderators
hammerswinger
from United Kingdom
Thanked: 25 times
PostPosted: Mon May 17, 2010 9:48 am Reply with quote
Do you mean you can't get the new olive onto the pipe because of the flair on the end of the pipe?
Cheers.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 51 times
PostPosted: Mon May 17, 2010 12:13 pm Reply with quote
If it has crushed the pipe you either need to cut it back or extend it or leave the original nut and olive in place I'm afraid.
Back to top
 Alert Moderators
landyandy
from United Kingdom
Thanked: 60 times
PostPosted: Mon May 17, 2010 1:48 pm Reply with quote
Original olive back on and apply a couple of wraps of ptfe tape around the olive.
Andy.
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
PostPosted: Mon May 17, 2010 11:07 pm Reply with quote
Word of advice. When replacing rad valves leave the old olive and nut in place, most likely they will be fine. You will do more harm taking it off. As suggested a few wraps of PTFE round the olive and tighten. If you still have a problem, cut the pipe down further and use a soldered coupler fitting to raise the pipe up to the new rad valve.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Removing an Olive from 15mm Chrome Plated Copper Pipe 2 920 Sat Aug 25, 2007 4:57 pm
Olive removing tool 59 44120 Thu Sep 28, 2006 9:55 am
Olive Removal 4 780 Sat Sep 29, 2007 6:29 pm
radiator valve olive 3 560 Mon Jul 30, 2007 8:37 pm
Sealing compound/paste around the olive? 14 2080 Sat Jan 26, 2008 9:42 pm
DIYnot
