Advice on refilling a primatic system.
1 Apr 2007
Cardiff
Going to remove some old twin entry valved rads this weekend and the system they have is a primatic. Only done this once before and luckily there where no issues. Any advice (just in case) on refilling this system should i get problems?. More worried but getting an air lock more than anything else, should i leave the hot tap open when i refill, i assume this is too prevent airlocks ?
I always leave a hot tap open and fill it slowly.
As above, tap open, then when the water runs clear, turn it off and then vent all the rads starting with the lowest.
