DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Garden Socket
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
  View previous topic :: View next topic
Author Message
faggster
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 12, 2005 7:55 pm    Post Subject:
Garden Socket
Reply with quote Thanks
Hi I don\\\'t know that much on how to do this but I currently have a hole through the wall for a pond pump plugged into an RCD usi a normal 3 pin plug. We want to put some patio lights up and I was thinking about putting a weatherproof switch out in the garden one switch for the pump and one for the garden lights. Could i just use the existing plug idea to power the new switch junction box and then power my two devices off of it??
Thanks in advance.
Paul.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 12, 2005 8:06 pm    Post Subject:
yes. make sure you still have RCD protection. if you do it thru a plug, youll be exempt form part P
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Mar 12, 2005 8:51 pm    Post Subject:
What are:
The rating of the pump
The rating of the lights
The rating of the fuse in the plug
The size of the cables
The type of cables (ordinary flex, hi-tuf etc)
The routes that the cables will take to the switch, and from the switch to the lights and the pump
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
fitting twin plug socket into my garden shed 4 220 Thu Sep 10, 2009 3:41 pm
What size mcb for garden socket 17 560 Sat Apr 12, 2008 1:50 pm
Armoured cable from CU to 13amp socket in garden 7 1020 Tue Nov 22, 2005 1:40 pm
spur 30amp garden socket 3 220 Sun Jun 22, 2008 10:09 pm
Garden Supply Socket 8 280 Mon Jul 14, 2008 2:34 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
