Ok so I thought this was a simple one; I thought that if the heating system is switched off, ( on the thermostat and on the dial on the boiler), I could cut the pipes feeding to the rads and continue to operate the boiler for hot water for showers etc. But the shower water is cold.
This could just be me being impatient as I switched the electrics to the boiler off when I cut the pipes, (in case they spurted and drenched things), and only switched them back on 15minutes ago..... but I thought the point of a combi was that it heated water instantly?
PS If you're wondering why I wanted to cut the radiator pipes it is because I'm doing a major house refurb and the radiators will all need to be moved. As it was a retrofit CH system the pipes are all over the place so will need to be re run under floors etc. Pretty much redoing from scratch. The boiler also needs to move at a later date- (I'm aware boilers don't move well and I'll probably need a new one!) So I drained down the system, removed the rads to storage, and cut the pipes to the boiler.
I wish I'd checked I hadn't sabotaged the hot water before going for a long cycle ride this evening. I want a hot shower!
So;
QUESTION 1- Can you run a combi boiler with the rads pipes cut?
QUESTION 2- If there needs to be water in that part of the system can I join the 2 cut pipes into a mini loop, refill them with water and then run the system
QUESTION3- By trying to run the boiler for hot water just now am I liekly to have fried/ destroyed something?
So;
