Hi, some may remember in January that I had a problem with the above boiler due to it 'banging' loudly when the room thermostat was satisfied and the pump went off, but not the burner.
see //www.diynot.com/forums/viewtopic.php?t=211602 for more info.
Anyway, to cut a long story short, The engineer finally replaced the internal boiler stat. last week and the banging faded away but was still there, albeit quieter though. However on Thursday there on its initial fire up for heating I banged loudly once more, the engineer now suspects that it is sludge in the heat exchanger causing the thermal movment.
My question is, is there any chemical you can use (sentinel --??) to remove or even just break up this sludge? I also saw 'boiler silencer' in Screwfix, would this be any help?
Again thanks for any help you can offer and if you have any other suggestions, i'm all ears
