This is a 1996cc injection with a rather unusual looking "carb".
The accellerater cable twists a puley on the carb which is spring loaded and returns sharply.
The basic idle speed is about 850 rpm but often returns to 1300 and stays there for several seconds.
What sets the minimum speed?
Whats likely to be causing the reluctance to return to the real idle speed.
There is a kind of diaphragm valve on the two tubes which allow the carb to suck air from the crankcase and rocker cover. Is this likely to be sticking and causing the problem?
Tony
Tony
