DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hyundia Atoz
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
davidstanton
from United Kingdom
PostPosted: Tue Mar 15, 2005 10:51 am Reply with quote
Hi
Can anyone provide me with technical service data (gaps, timing, etc etc) for the Hyundai Atoz.
Back to top
 Alert Moderators
jonnyfishing
from United Kingdom
Thanked: 27 times
PostPosted: Tue Mar 15, 2005 10:16 pm Reply with quote
Settings for HYUNDAI ATOS AMICA 1.0i 1998-2004. eng.code G4HC as requested......
IGNITION TIMING=9 DEGREES @900rpm
IDLE SPEED AND C.O. IS NOT ADJUSTABLE.
SPARK PLUGS=NGK-BKR5ES-11.....GAP=1.0-1.1
VALVE CLEARANCE (HOT)=0.20mm INLET
(HOT)=0.25mm EXHAUST
ENGINE OIL=10W/40 SJ/A2-96..................... 3.1 LITRES WITH FILTER
MANUAL GEARBOX OIL=SAE 75W/85W ......... 2.2 LITRES
AUTO.FLUID= HYUNDAI ATF.......................... 4.0 LITRES
HOPE THIS HELPS YOU OUT...IF YOU NEED ANY MORE INFO.JUST ASK.
Back to top
The following user says thank you to jonnyfishing for this useful post:
Brudan (28 Apr 2011)
 Alert Moderators
davidstanton
from United Kingdom
PostPosted: Tue Mar 15, 2005 11:05 pm Reply with quote
Thanks. Alot cheaper than the 240 that Hyundai want for the workshop manuals!!
Back to top
 Alert Moderators
Davatos
from Malta
PostPosted: Thu May 05, 2005 12:34 pm Reply with quote
Hi Davidsanton,
I have been searching for a workshop / repair manual for the Hyundai Atos 2002 model for quite a long time but to no avail.
The local agents in Malta for Hyundai refused to sell it to me and the Hyundai mothercompany didn't even bother to reply my mail.
At least you got a quote of the cost of the manual.
I still need to obtain this manual. Did you manage to find a cheaper repair manual for this vehicle?
Thanks also to jonnyfishing. His tehnical data is has been taken note of.
Dav
Back to top
 Alert Moderators
davidstanton
from United Kingdom
PostPosted: Thu May 05, 2005 12:47 pm Reply with quote
Hi
No I didn't manage to find another manual.
David
Back to top
 Alert Moderators
Brudan
from South Africa
PostPosted: Thu Apr 28, 2011 8:37 pm Reply with quote
Does any one know if the following settings will work for a Hyundai Atoz Prime 2005-6?
Read more: http://www.diynot.com/forums/viewtopic.php?t=22744#ixzz1KqtUsUS2
Back to top
 Alert Moderators
jonnyfishing
from United Kingdom
Thanked: 27 times
PostPosted: Fri Apr 29, 2011 11:03 am Reply with quote
See if you can find what you are looking for here:- www.carfolio.com/specifications/models/car/?car=127743
Back to top
 Alert Moderators
goldfever1
from United Kingdom
PostPosted: Sun Apr 01, 2012 9:03 pm Reply with quote
Back to top
 Alert Moderators
Arthur2shedsJackson
from United Kingdom
Thanked: 16 times
PostPosted: Wed Apr 04, 2012 12:57 pm Reply with quote
And your point gf1 was ???
Back to top
 Alert Moderators
goldfever1
from United Kingdom
PostPosted: Wed Apr 04, 2012 9:00 pm Reply with quote
is the valves hydraulic on the 1998/99 atoz are these not adjustable ?
that is what i was asking, as i had to tke off all drive belts not the timing belt to replace a timing cover and changed all fluids oil included and put everything back together and now it sounds like a diesel makes a right racket,took of rocker cover and everything was as dry as a bone looks like no oil reaching tappets so thought these might want checking but are they adjustable or not ? but gonna get oil round first and then look into the rocker cover again if it still sounds like a diesel lol sorry guys i only a female who likes gettin her hands dirty lol ty ev1 icon_lol.gif
Back to top
 Alert Moderators
Arthur2shedsJackson
from United Kingdom
Thanked: 16 times
PostPosted: Sat Apr 07, 2012 8:27 pm Reply with quote
Have no experience of the Hyundai Atoz, but try this website for an answer
http://www.justanswer.com/sip/hyundai-vehicles?r=ppc|ms|3|Rest+of+World|Hyundai&JPRC=1&JPKD=8874612495&JPDC=p&JPAD=815116094&JPKW=on%20Hyundai&JPRQ=are%20valves%20hydraulic%20on%20the%20hyundai%20atoz%3F&JPAF=txt&JPCD=20120207
It seems unusual that the noise should develop after work, particularly since you changed the oil, because the top of the engine shouldn't be dry after you've just topped up the oil. Quite the opposite really.
Did the oil light go out when you stsrted it?
Back to top
 Alert Moderators
goldfever1
from United Kingdom
PostPosted: Sat Apr 07, 2012 10:16 pm Reply with quote
did not notice the oil light,but as the weather has been quite bad not been able to progress with the car but will start again in the moning ie sunday
Back to top
 Alert Moderators
goldfever1
from United Kingdom
PostPosted: Wed Apr 11, 2012 7:41 pm Reply with quote
right we have fixed the noisey engine whic is now purring not growling like a diesel lol we took off the rocker cover and did all valves inlet and gas now perfect so quiet had all new oil plus fluids changed also. now the problem i have is not with the engine Its the drive belts or pulleys that is making a noise souds like a dry pump noise sort of soft rubbing also not a clue what it could be sound seems to get louder as the engine heats up ! not there on initial start up !! left it running to see if fan kicked in and yes it did so any ideas guys thankyou. icon_confused.gif
Back to top
 Alert Moderators
Arthur2shedsJackson
from United Kingdom
Thanked: 16 times
PostPosted: Wed Apr 11, 2012 8:11 pm Reply with quote
Belt too tight, not tight enough ?
Back to top
 Alert Moderators
goldfever1
from United Kingdom
PostPosted: Wed Apr 11, 2012 8:24 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Hyundia Atoz Gearbox conversion 3 620 Wed Nov 09, 2005 10:57 am
Hyundai 1999 Atoz air bag light 9 200 Sun Jun 23, 2013 7:14 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2014 DIYnot Limited.
