| Author |
Message |
reevsy
Joined: 26 May 2010 Posts: 5 Location: Plymouth, United Kingdom
Posted: Wed May 26, 2010 8:00 pm |
Good evening,
I have a problem with my Baxi Boiler (Solo HE Range) and its control panel. There is no power going to the boiler or control panel. I have checked the fuse and that is OK.
Any Ideas where to look next?
Regards |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41397 Location: London, United Kingdom Thanked: 1337 times
Posted: Wed May 26, 2010 8:13 pm |
How did you determine that there is no power going to the boiler or control panel?
Does the circuit supplying the boiler supply anything else? |
| Back to top |
reevsy
Posted: Wed May 26, 2010 8:20 pm |
Thanks for reply.
The control panel had a orange back light that was always on this is now out but still has digits that are still visible. The buttons have no effect on the boiler.
I guess im guessing that there is no power going to it, the boiler is 10 months old. It would appear to have no power going to it?!?
As you can see I'm a DIY noob, any suggestion appreciated. |
| Back to top |
ban-all-sheds
Posted: Wed May 26, 2010 8:58 pm |
Where/how is the boiler connected to an electricity supply?
You say you checked the fuse - what fuse? Where?
Do you have a multimeter?
You need to find out for sure if power is getting to the boiler or not. If not you need to find out what is stopping it, and where, if it is then you need someone to fix the boiler. Or check on the CH forum - should be safe enough to ask about this. |
| Back to top |
joe-90
Joined: 28 Oct 2005 Posts: 26247 Location: United Kingdom Thanked: 789 times
Posted: Wed May 26, 2010 9:00 pm |
Isn't it under warranty? |
| Back to top |
reevsy
Posted: Wed May 26, 2010 9:05 pm |
Many thanks.
I checked the fuse that is on the switch plate (looks like a light switch). fuse comes out on a tray.
I dont know what else os on the same circuit either, sorry. I have a multi meter, Ill follow your advice thanks.
Gavin |
| Back to top |
reevsy
Posted: Wed May 26, 2010 9:08 pm |
Yes it is. Just seeing if i is a easy fix. |
| Back to top |
1john
Joined: 03 Oct 2009 Posts: 3336 Location: West Glamorgan, United Kingdom Thanked: 336 times
Posted: Wed May 26, 2010 10:03 pm |
Prob blown the 2amp fast blow fuse in the boiler which fuses the supply to the PCB. |
| Back to top |
bongos
Joined: 07 Jul 2007 Posts: 969 Location: Sheffield, United Kingdom Thanked: 77 times
Posted: Thu May 27, 2010 9:01 am |
| reevsy wrote: | | I checked the fuse that is on the switch plate (looks like a light switch). fuse comes out on a tray. |
How did you check the fuse?
Is there anything else on this circuit? Are you able to open the FCU and chek for 230v using your multimeter? |
| Back to top |
ban-all-sheds
Posted: Thu May 27, 2010 9:05 am |
Or look into 1john's idea - the reason I suggested asking on the CH forum was in case someone said "Baxi Solo HE? Yeah - well known for <some-fault-or-other> - check that first". |
| Back to top |
reevsy
Posted: Thu May 27, 2010 9:01 pm |
Thanks for all replies. I have found the problem to be the timer/conrol unit. Power is not being sent to the boiler.
At least its not the boiler  |
| Back to top |
