DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Gas flue vent distance from window??
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rsthomas11
from United Kingdom
PostPosted: Thu May 27, 2010 9:13 am Reply with quote
I am having a conservatory built and I will have a glazed window (non-opening) near to my boiler's gas flue vent. I'm not sure of exact distance but currently it is 300mm from the centre of the vent to my kitchen window frame. The conservatory will be just outside the window therefore approx. 250mm. The top & other side of the vent is clear and is over the height of my neighbour's fence (i.e. not enclosed any further on any other side, just the one where my new conservatory will be).
I have had two heating engineers to visit and they both seem to unsure of the current regulations which is worrying! Can anyone on here help?!
I have looked into extending the flue upwards but they don't seem to do the correct vertical extension kit for my boiler. If anyone can help with this too I would be grateful. My boiler is a Potterton Suprima 30 (standard efficiency) installed in 1998.
Back to top
 Alert Moderators
Axel
from United Kingdom
Thanked: 78 times
PostPosted: Thu May 27, 2010 9:38 am Reply with quote
Back to top
The following user says thank you to Axel for this useful post:
rsthomas11 (28 May 2010)
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Thu May 27, 2010 9:48 am Reply with quote
That seems rather worrying are they bon fide Gas Safe registered?
See page 42/43 here;
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2002.pdf
New edition applies from October 2010.
Back to top
The following user says thank you to Richard C for this useful post:
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Thu May 27, 2010 9:49 am Reply with quote
Sorry Axel didn't check before posting.
Back to top
 Alert Moderators
Axel
from United Kingdom
Thanked: 78 times
PostPosted: Thu May 27, 2010 9:55 am Reply with quote
Fair enough...I was going on the basis that the MI's superseed the BS regulations.
I suppose that presenting a new clearance to a flue could be counted as re-fitting or installing a new flue, in which case the new regs would apply.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Thu May 27, 2010 9:56 am Reply with quote
All measurements have to be made form the OUTSIDE of the flue.
So as your flue is within 300mm it is already too close to the window based on the CORGI interpretation which is likely to be continued by Gas Safe that 300mm applies because the window could be replaced with an opening one at any time.
Only condensing boilers can have their outlet gases diverted away from the terminal externally. All others have to be moved internally.
Dont expect flue parts to be readily available for 10 year old boilers.
Tony
Back to top
The following user says thank you to Agile for this useful post:
 Alert Moderators
rsthomas11
from United Kingdom
PostPosted: Thu May 27, 2010 10:12 am Reply with quote
Axel wrote:
So would my description above be described as J in the above key - therefore 600mm??
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Thu May 27, 2010 10:19 am Reply with quote
You have not given details of your neighbours boundary.
The 600mm is the official minimum distance from the centerline of the boundary to the closest part of your flue.
Its not very important in practice as its not normally a gas safety issue, just a matter of not annoying your neighbour.
Tony
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Thu May 27, 2010 11:37 am Reply with quote
the other thing to consider is the requirement for a flue to be more than 150mm from a fabric opening in a building ie where the window frame meets the building, so the existing flue is well inside the requirements
on this point, how would you classify a room sealed flue too near an opening in a building as per CURRENT edition of IUP
Back to top
The following user says thank you to kirkgas for this useful post:
 Alert Moderators
simond
from United Kingdom
Thanked: 273 times
PostPosted: Thu May 27, 2010 8:07 pm Reply with quote
I think you'll find the diagram posted above by Axel is not for a 1998 Suprima.
Correct me if I'm wrong - I won't fit Poxi Batterton so am not familiar - but I reckon it is a Suprima HE manual, and thus of no relevence to the OP.
Back to top
The following user says thank you to simond for this useful post:
 Alert Moderators
rsthomas11
from United Kingdom
PostPosted: Fri May 28, 2010 9:46 am Reply with quote
Thanks Simon, I have found the original manual online via the Potterton website and it shows a similar drawing with dimensions. It seems like I only need 25mm (fingers crossed!) gap to an internal/external corner and I am waiting on confirmation from the heating engineer.
Thanks everyone else for your help.
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 1058 times
PostPosted: Fri May 28, 2010 3:46 pm Reply with quote
The OP said:
So the regulations about the distance of the flue from a opening window are irrelevant. It's only the distance from the internal corner formed by the existing wall and the conservatory wall which is relevant.
Back to top
The following user says thank you to D_Hailsham for this useful post:
 Alert Moderators
rsthomas11
from United Kingdom
PostPosted: Fri May 28, 2010 4:14 pm Reply with quote
D_Hailsham wrote:
Yes, I don't think I explained myself very well in the opening post (sorry everyone!) but the conservatory is enclosing the existing kitchen window and the new conservatory window pane coming out away from the house adjacent to the flue will be approx. 150-200mm away from the flue. I was worried this would be too close but I think it is covered by the internal/external corner dimensions quoted so therefore I need 25mm gap - which I will have.
Thanks everyone!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3490 times
PostPosted: Fri May 28, 2010 8:43 pm Reply with quote
Be aware that neither the OP nor D Hailsam are gas registered.
They are making up their own intrepretations of the manufacturers instructions.
A conservatory in terms of MI is a window and not a wall.
Whilst I agree that the MI does not cover the OP's situation, its only the manufacturer who should advise when there is no clear information given.
Another aspect often ignored is that the flue can only be fitted in a location where it will not cause any "nuisance".
Tony
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sat May 29, 2010 12:58 am Reply with quote
Whilst D Hailsham or op is not registere they both have a better understanding of the the regs than you Agile
You are certainly a nupty
Scary who is allowed to be ACS registered
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Safe distance between boiler exhaust flue and bedroom window 4 120 Sat Nov 16, 2013 5:09 pm
Required distance from boiler flue to window 3 60 Fri Sep 20, 2013 8:18 pm
Vaillant vertical flue (distance from window) 7 140 Mon Nov 12, 2012 10:52 am
gas fire to window distance? 6 620 Tue Aug 22, 2006 6:45 pm
boiler flu-- distance from window 4 940 Fri Oct 24, 2008 6:20 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
