Hi, hope some one can help me with this - i thought it was going to be straight forward.
I've got an outside PIR security light that I want to replace with a normal door light that can be switched on/off from inside.
When I removed the PIR light it has 4 wires, live, neutral, earth (which I think comes from a switched spur) & and extra L1 (which i think comes from the light switch inside). This all works fine but I have no need for the 300W PIR.
The new light I bought (massive manchester) is a normal switch on/off but inside only has live & neutral connections.
I'm not sure what I should be doing with 2 of the wires (1 eatch & 1 live)??
Is it safe to choc block them & insulation tape, then just use the neutral from switched spur and live from light switch?
Cheers
Cheers
