DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to hold down and seal kitchen sink?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Agile
from United Kingdom
Thanked: 3534 times
PostPosted: Thu Jun 10, 2010 1:33 pm Reply with quote
I agreed to connect up a kitchen sink for a customer whose boiler I have been repairing for a few years.
The new kitchen had been fitted by an installer from Europe who has now left the country without totally completing the job.
They have apparently bought some double sided adhesive tape and asked me to fit the sink using that. The sink is a B&Q standard stainless sink with no mechanical method supplied to hold it in place.
My question is whether double sided adhesive tape is an acceptable way to hold down the sink and provide a water tight seal?
Tony
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2568 times
PostPosted: Thu Jun 10, 2010 1:39 pm Reply with quote
There would normally be double sided foam tape plus 10 or so claw type clips, which clip onto the sink underside then extend under the worktop onto which they bite up....I guess these have gone astray.
I wouldn't be happy with a tape seal alone to hold the sink down permanently.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3534 times
PostPosted: Thu Jun 10, 2010 1:47 pm Reply with quote
That what I had expected using claw clips to hold it down.
It was really a job from hell! The kitchen taps had parts missing and they had to get it replaced and eventually had a new tap and spare missing fittings as well. The sink was damaged and had to be replaced. Thats B&Q for you!
Trouble is a non tech son was buying the bits and an experienced kitchen fitter doing the work but apparently not with much interest apart from finishing and leaving!
There were bits all over the place and I had a good look round but no sink fixings.
Are they supplied loose with the sink, sold seperately or should they have been taped onto the sink?
Tony
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Thu Jun 10, 2010 2:24 pm Reply with quote
They are usually around a dozen of them in a small plastic bag along with a strip of double sided, closed cell foam & the fixing instructions but I'm pretty sure you can get sink fixing kits as a separate item.
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Thu Jun 10, 2010 3:25 pm Reply with quote
Frightenin that someone who is qualified to fit boilers etc cant even work out how to fit a sink icon_rolleyes.gif
Back to top
 Alert Moderators
EddieM
from United Kingdom
Thanked: 58 times
PostPosted: Thu Jun 10, 2010 3:32 pm Reply with quote
Nah, don't bother with the clips. Just run some good quality transulscent sealant on the underside of the sink rim, fit in place and weigh down. Once the sealants cured, leave it overnight, then just cut the excess off. Worked for me.
Back to top
 Alert Moderators
barryauid
from United Kingdom
Thanked: 14 times
PostPosted: Thu Jun 10, 2010 4:01 pm Reply with quote
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 708 times
PostPosted: Thu Jun 10, 2010 5:22 pm Reply with quote
I thought any numpty could fit a sink!!!!cut the hole seal with some varnish or silicone ,and then clamp the sink down again using clear silicone and the clips provided by the manufacturer,personally i never bother using that double sided tape
Ah well looks there is one numpty who cant,the merits of being a proper qulaified plumber and heating engineer !
Agile you should go on one of those 6 week wonder courses to teach you how to plumb.
You should that junior engineer Nickso,i bet he could fit a kitchen sink without having to ask on public forum
Back to top
The following user says thank you to Happyplumber for this useful post:
assured heating (12 Jun 2010)
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 127 times
PostPosted: Thu Jun 10, 2010 5:23 pm Reply with quote
You can buy spare clips if required (pg 264 of Plumbfix cat for example), however silicone should do the job.
Edit: Remember to apply clear silicone to the inside of the cut out in the worktop too.
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 708 times
PostPosted: Thu Jun 10, 2010 5:27 pm Reply with quote
Back to top
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 127 times
PostPosted: Thu Jun 10, 2010 5:33 pm Reply with quote
Happyplumber wrote:
looks like we hit the "submit" button at the same time , have never used varnish, always use silicone as it's whats on the van
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 708 times
PostPosted: Thu Jun 10, 2010 5:43 pm Reply with quote
Varnish is actually better then silicone because it penetrates right into the chipboard unlike silicone which just sits ontop mate ,each to their own though,when i dont having any quick drying varnish then i too use clear sanitary silicone icon_cool.gif icon_cool.gif
Back to top
 Alert Moderators
Mark Br
from United Kingdom
Thanked: 127 times
PostPosted: Thu Jun 10, 2010 5:48 pm Reply with quote
Top Tip - Never thought to use it before.
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 708 times
PostPosted: Thu Jun 10, 2010 6:06 pm Reply with quote
That was method showed to me about 25 years ago,by an old school plumber ,who has now passed away may god rest his soul
Back to top
 Alert Moderators
1CANHELP
from United Kingdom
Thanked: 17 times
PostPosted: Thu Jun 10, 2010 6:46 pm Reply with quote
Funny that eh! old Tony boy the short course wonder and there is me thinking he knows everything...NOT.
For gods sake I am surprised he gets any work done the amount of time he spends on here talking rubbish.
Sure your not an architect or building control officer...I mean you seem to
Know a little about everything and Not a lot about much
Anyway! as usual when he's made a idiot of himself he'll go and hide.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Toilet: Slow flush unless i hold onto the handle 2 220 Sun Jul 18, 2010 4:59 pm
How to hold a bath tap still 23 1080 Sat Jul 18, 2009 2:35 pm
Vaillant won't hold system pressure 3 100 Mon Jan 03, 2011 5:37 pm
Have to hold in Button for Short flush on Toilet Cistern 7 60 Tue Oct 29, 2013 10:53 am
Shallow Well Pump Won't Hold It's Prime 5 660 Thu Apr 01, 2004 3:46 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
