DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wiring switches
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
  View previous topic :: View next topic
Author Message
richard b
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 18, 2005 9:29 pm    Post Subject:
wiring switches
Reply with quote Thanks
i need to wire a light switch, 2 switches on one plate, is this a two way?? i need an idiots guide on how to wire it up. The switch is to control 2 wall lights!! icon_rolleyes.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
theshogun
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 18, 2005 9:41 pm    Post Subject:
Look in the for reference at the top of the posts
Back to top
 Alert Moderators
richard b
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 18, 2005 9:55 pm    Post Subject:
thanx for your reply but i have a normal 3 wire supply from the socket brown,blue yellow/green, and a brown and blue wire for each light (x2) how do i wire this up to a 2 way switch?? icon_redface.gif
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Mar 18, 2005 10:38 pm    Post Subject:
as has been said look in "for refernce" (one day i will spell that correctly)
If you can not understand how to do it after looking at for refernce is suggest you are not competant to do the job and that you get some one else to do it for you.
This is nothing personal, some things some people can do and some others must do
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Mar 19, 2005 1:09 am    Post Subject:
Socket?
Lights?
2-way switch (I think you mean 2-gang)?
This is not a good combination of things.
Remember that you used the word first - how much of an idiot are you?
Do you know the difference between Live, Neutral and Earth, and what a switch does?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 19, 2005 10:59 am    Post Subject:
It sounds like you want to connect two wall lights to a surface mounted two gang light switch then take a three core wire from this and plug it into a socket (3 amp fuse in the plug). That's unconventional to say the least but safe if you can find a way of clamping the wires' outer sheaths inside your switch box (which won't be easy).
Alternatively, is that three core wire taken straight into the back of the socket? You can't do that. The socket will be on a 30 amp fuse and that's far too big to protect your wall light wires which are probably only 3 amp rated.
You have only two core wires coming from your lights. That's OK if the lights are class two (double insulated). If they are they will have the class two symbol stamped on them somewhere. Look for a square with a smaller one inside. There will also be nowhere to attach an earth wire.
If all of the above is in order the switch wiring goes like this:
Each switch will have a terminal marked COM, or maybe just C, and two others on the opposite side marked (probably) L1 and L2. You connect your incoming brown wire to both COM's and the outgoing brown wires to the L1's. All three blue wires go together in a piece of choc block. The green/yellow wire goes on its own in another choc block. If the switch works 'upside down' to what you are used to move the outgoing brown wires to the L2's.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Mar 19, 2005 11:03 am    Post Subject:
Felix, may i point out, that although you are offering your opinion, the poster is incompitent to do the job. I make this comment based on the facts provided by the poster them selves.
so your comments will no doubt go above their heads, some people can not grasp what others take in their stride.
__________________
Forum = Opinions
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 19, 2005 1:04 pm    Post Subject:
Fair comment from Breezer and I did consider it. I also considered the possibility that Richard b would read all the negative comments, say "useless t***ers" and do the job anyway but with information acquired from behind the bike sheds. The fact that he bothered to post on the forum at all is promising.
Richard b, you do need to learn more and remember, live wires bite!
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Mar 19, 2005 1:20 pm    Post Subject:
you have put it better than i icon_redface.gif , and yes i agree with you
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wiring two and three way switches 4 520 Tue Sep 13, 2005 1:15 pm
Wiring for 2x 2 Gang 2 Way switches 12 3100 Thu Aug 30, 2007 4:48 pm
Wiring New wall switches 7 220 Sun Aug 10, 2008 3:52 pm
Wiring Old Light Switches to New Ones 3 320 Sat Oct 08, 2005 2:38 pm
Wiring switches in new lighting circuit 2 240 Mon Aug 13, 2007 3:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
