Fused spur
13 Jun 2010
Glasgow
I am looking for some guidance on installing a fused spur for underfloor heating. The heating mat is 10msq x 200watts so 2000watts total. I have been advised this can be installed off a 13amp fused spur which is fine as I have a double socket and single socket located directly through the wall from the installation (house has concrete floor so it difficult for running cable). My question is can I also spur off the double/single cocket to install sockets in the room of with underfloor heating.
Sockets are to 32amp breakers on the consumer unit.
thanks .
You need to test and check to see if the double and single outlet are in fact a ring.
Isolate the power (check for dead).
Remove either socket.
Look for continuity between L - L, N -N, E - E.
This will tell you if you have a ring.
You can supply one single or double socket or one FCU per spur.
If you want more sockets than that they they would have to be supplied through a 13A FCU and the total load would be limited to 13A. (The triple sockets you can get include a 13A fuse and count as a fused spur.)
Not sure if I'm understanding you, can I take one 13A FCU from my existing socket and then a further 13A FCU from the 13A FCU already taken.
I'm going to get an electrician in to do the work but want to know if what I need is possible or not.
You could do as you ask.. aslong as the exisiting socket and fcu are part of a ring circuit. Which you won't know unless you test as i said above.
ok thanks I'll let the electrician test for this and take it from there.
I have just been informed that the sockets are in a ring circuit, does this enable me to take the 13A fcu for the floor heating and two double sockets from the existing double and single socket in adjacent room?
Theres a few different ways of doing this, either way your electrician will be able to take power from that point.
As its a ring main can I break into the ring and add 2 or even 3 double sockets and also take a 13A fused spur from the existing double socket.
Your electrician will know what to do, including testing to see if any particular cable is actually part of a ring final and not a spur.
Yes you can, as long as you (or. ahem, your electrician) extend the ring and don't just spur from it.
All this faffing is one of the reasons I don't like ring circuits.
