hi all, i have recently treated and flushed the C/H system. since then the hot water has been a brownish/orange colour. shurely the hot water and heating water shouldent mix in the cylinder? any ideas would be greatly apreaciated
depends what type of cylinder you have it should say on it what type it is. If it is a primatic you should not have added any inhibitor to it and may have got rid of then internal air bubble in the cylinder which keeps the dhw away from your ch water
thanks gasman, not the best news but if needs must . do you think replacing it with the same type or a primatic? from what tomy's saying, you can't treat the system with a primatic
