Hotpoint WD62 Program Cycle Problem
19 Mar 2005
Derbyshire
My WD62 washer dryer switch does not function properly. When trying to perform a wash it will fill up with water then just keep clicking. The switch will rotate so far then stop. The drum does not move at all during this time. Also anyone know how to clean the filter out on this model ?
will it spin in any prog? it sounds like you need new motor brushes
I've pulled the machine out from where it sits under the worktop, took the top off, poked and fiddled with the motor, tried the program cycle and it spins fine. Noticed though that when spinning, I can see little sparks from the inside rear of the motor. Is this normal or are the brushes shot ? Also i've pushed the washer back under the worktop and now it does the same thing as it did before - not spinning, only filling with water !
Fitted new brushes. Cost me a tenner. Machine works like new. Got the missus off my back at last :D
