Shed Wiring Help Required
16 Jan 2008
Hi
Im looking to have my shed wired with the following:
1) 8x double sockets
2) 2x Strip Lights
3) 1x Motion activated security light
4) Two small water features run from a waterproof double switch on outside of shed.
I was hoping to get some advice on what materials i need.
The house is RCD Protected (board is full) and has an earth stake. The intention is to run the shed from a seperate CU which i already have (6 way board with 1 x 32, 1 x 20, 1 x 16 and 2 x 6 amp MCB)
My only querie really is that the shed is 30 meters away from the house so would i need to have a single CU Swith MCB/RCD at the main board end or would it be ok to run the Armoured cable straight off the main board to shed CU.
I will be getting an Electrican to do the wiring its just that i want to get the parts delivered ready for him to start once i found someone local. I will be running the Armoured Cable (which we already) have down myslef and chasing the walls ready to try and save a bit of money on the labour.
Any help you can offer would be great.
Best Regards
Neil
You really need to speak to the electrician you have in mind to install the work, he will help you design it correctly taking all factors and loads in to consideration and offer you a material list, but your electrician will more than likely hold a trade account at a wholesalers that will offer bigger discounts than you are likely to get.
If the existing board is full then surely you don't have much choice in the matter?
