DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
STOPCOCK SIEZED
This topic originated from the How to page called Reseating a tap
Click here to return to the page called Reseating a tap.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
wally
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 20, 2005 12:21 pm    Post Subject:
STOPCOCK SIEZED
Reply with quote Thanks
Stopcock siezedin house.No outside mains stopcock visible on pavement or road.situated in small village & local plumbers want a fortune to do the work. I have heard about freezing the pipe but is their any other method.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
doitall
from United Kingdom
Thanked: 240 times
PostPosted: Sun Mar 20, 2005 12:56 pm    Post Subject:
Get the water company to find it, or failing that the old bent coat hangers makes great diving rods icon_lol.gif
Could always dig a hole to the pipe and cut it in half and fit a new one, great fun if you have the nerve to cut a live mains.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sun Mar 20, 2005 1:05 pm    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sun Mar 20, 2005 1:08 pm    Post Subject:
Try loosening the gland nut under the spindle and spray lots of wd 40 on it .
Leave to penetrate.
If this works turn your water off and fit a new stoptap further up the line. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
watertight
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 20, 2005 1:38 pm    Post Subject:
Wally,
How old is the property, what type of property is it?
If it's an old victorian terrace it could be that there is a means of turning off your supply at a neighbours house upstream.
Mark
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 1 time
PostPosted: Sun Mar 20, 2005 8:56 pm    Post Subject:
hire an electric pipe freezer for £50 they work very well
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sun Mar 20, 2005 9:02 pm    Post Subject:
__________________
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Sun Mar 20, 2005 9:19 pm    Post Subject:
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Twiney
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 02, 2005 1:57 am    Post Subject:
Did U try the freezing kit Wickes sell them do they work??
Back to top
 Alert Moderators
oldskool_plumbski
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 14, 2006 11:19 am    Post Subject:
stuck.
freeze it. simple job,dont panic, follow the instructions on the can, no need to replace the whole thing, once frozen,remove the body from the existing and new tap, exchange bodies..
Be warned, if it's not looking likely to fit,dont cross thread, replace the old one and then call the water board, unless you can remove the whole stop cock within the allotted freeze time.
Other than that (room permitting) slice of pipe three inches below ceased valve(one frozen) and whack the valve on then.
Make sure the new valve is in the off position when fixing to incoming supply.
PS: use a pipe slice,not an hacksaw,this will give you a cleaner cut,and no need to de-burr.
Back to top
 Alert Moderators
bikerm4
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 14, 2006 11:36 am    Post Subject:
Think he will have sorted it by now, it was 12 months ago!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Mar 14, 2006 11:45 am    Post Subject:
It's always worth trying the water company, one of my chums had the same prob, no sign of a stopcock in the pavement.
Water co came along with their diving rods, discovered it had been tarmacked over, dug it out, fitted a new hatch, remade the pavement, great job done. no charge.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Mar 14, 2006 11:46 am    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cold tap siezed on 3 2880 Sun Jul 16, 2006 1:27 pm
Gate Valve siezed 7 800 Wed May 11, 2005 8:10 pm
Stopcock 2 140 Mon May 19, 2008 7:14 pm
Main stopcock 16 660 Wed May 28, 2008 8:16 pm
stopcock won't turn off!!!!!! :( 6 620 Tue May 13, 2008 4:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
