I am currently leasing a flat and the letting agent just placed a Worchester Bosch Greenstar 24i junior combi boiler. I could not find the water tank in the flat, so I am assuming the tank is shared or its based on a direct water system.
There are a few problems I have encountered:
1. When I turn on one tap (either hot or cold) and turn the other tap, the water pressure of the taps drop. Its like the water pressure is cummulatively shared between hot and cold water.
2. When there is a sudden need of water like after flusing down the toilet or during washing clothes, I notice that there is no hot water at all when turning on the tap. Only cold water comes out. Once the the tank is full or after washing is done, hot water comes back.
I am currently using some sort of eco button with a timer so the water is only heated at specific times of the day. Says in the manual, no preheat water is available. but it does not matter as the timer fixes that problem. Since its summer, I don't need it turned on all the time. What I do notice is that even though I do the washing outside the timer period, the hot water temperature is not affected after that. So I am guessing there is sufficient hot water to last me the entire day. The system pressure guage is within normal water pressure.
Any ideas how to tackkle the problem? Thanks all for the help.
