Further to recent posts.... completed drain down/flush. Changed a couple of leaky rad valve, re-filled, re-started. No major problems - this time no banging from the boiler (did a slow re-fill and was very careful with bleeding). However, one rad is still reluctant to heat up and I wonder whether this could be the problem.
We had our central heating piping re-routed - previously had feeds dropping down from a bedroom (yes the same one with the cool rad) - the feeds were cut off and capped. The capped pipes are approx 24 inches in length off the t's. Could these capped pipes be causing an airlock problem on the return of this cool rad, preventing proper flow of water?
P.S. IS the pump bled by undoing the central pump screw and when the air comes out does it make an interesting noise?
