ideal isar no heating
30 May 2007
hi, i have an ideal isar which does not heat the water. the controls are calling for heat because the boiler displays d when the hot water tap is opened, but the burner dosent stay on for long before it cuts out. i can just about manage a warm shower, if i turn the water flowrate down to a bare minimum.
Does heating work? Does heating get hot when you run a hot tap?
Favourite culprits would be plate heat exchanger / diverter valve / thermistor
hi thanks for the reply
just tried running the hot tap for about 5 min, the rads did not warm up. they do get hot when in c/h mode
yer thats what it does... the pump remains on but the burner comes on and off about every 30 sec
thanks petit,
can this be removed and cleaned i.e with a pressure wash or somthing?
It can be removed and cleaned although they are very fiddly on the isar.
Cleaning with spirit of salts or a central heating cleaner should do the job. Search the forum for cleaning plate heat exchangers, its been done to death before.
