I have brought a house with an Ideal HE C22/24 boiler but have started to suffer from poor temperature control in my shower.
All was well initially but now it cycles hot and cold. I have watched the boiler while the shower is on and the pressure gauge, which at rest indicated just below 1bar fluctuates between about 0.5 and 1.5 bar. Also, the burner intermittently goes out then relights causing the temperature variation in the shower.
If I turn the flow rate right down in the shower then I do get constant hot water but it never used to be necessary.
I wonder if the pressure needs topping up but cannot find how to do it - there is a fill loop but appears to be no easy to use taps/valves.
Any suggestions please?!
Skippmon
Skippmon
