DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Re-bar and mould oil.
Goto page Previous  1, 2
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
Norcon
from United Kingdom
Thanked: 193 times
PostPosted: Sun Jul 11, 2010 6:29 pm Reply with quote
Thanks for all the advice (its much appreciated) and sorry if I caused any offence.
Fwiw I agree about taking the structure back to the ground entirely.
The cost of this would run well up to £10k. Perhaps more.
Perhaps the SE will lend a hand on the concrete breakers??? Does their insurance cover for mistakes like this?
Before the threaded bar was used quite a number of phone calls were made by the prinicipal contractor to the SE and roofing engineer who both gave the go ahead for these undersized anchors to be used.
The ones we have now are 30mm grade 8.8.
Which I believe has a tensile strength of around 150,000 pounds per square inch.
Back to top
 Alert Moderators
geraint
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jul 12, 2010 9:17 pm Reply with quote
regsmyth wrote:
Thats some cantilever!
I'm suprised to hear that standard stud is ok as a replacement for HT holding down bolts. Especially if the stud is no larger than the spec HD bolts. Get it in writing and make sure BCO sees it.
I assume you'll use bolt boxes and washer plates, it gives movement with the full embedment depth.
whatever the strength of the holing down bolts... when they are covered over.. it means very little.. most holding down bolts will only be grade 46. i.e.soft steel...
Nice job!
Back to top
 Alert Moderators
geraint
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jul 12, 2010 9:19 pm Reply with quote
[quote="geraint";p="1670263"][quote="regsmyth";p="1659848"]Thats some cantilever!
Back to top
 Alert Moderators
geraint
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jul 12, 2010 9:23 pm Reply with quote
Nice job!
i have never come across ht holding down bolts... and never seen it specified what would be the point when it is encased...
Back to top
 Alert Moderators
regsmyth
from United Kingdom
Thanked: 28 times
PostPosted: Tue Jul 13, 2010 9:36 am Reply with quote
I've always used holding down bolts which are grade 8.8, which is a lot stronger than your standard grade 4.6.
The point is that if you use a high tensile bolt, the holes and hence edge clearances on your baseplate can be smaller than if you use grade 4.6, thus reducing overall steel costs.
Encasing them in concrete doesn't make them any stronger, but if they are fully encased, you don't need to worry about corrosion protection.
Back to top
 Alert Moderators
alittlerespect
from United Kingdom
Thanked: 47 times
PostPosted: Tue Jul 13, 2010 10:48 pm Reply with quote
Hi
The issue is to do with the design of the canopy being a cantilevered structure, the tie bars will be acting in tension to resist the overturning moment of the canopy and normal mild steel would not accommodate the embedded stress throughout the design life of the structure.
The concrete base/extension to the terrace is being used simply for its mass to resist the overturning moment and the only thing holding the roof in place are the tie bars.
Going by the SEs history he is likely to come back and ask for the 2 concrete pours completed to be demolished and rebuilt.
I would have anticipated costs for remedial works being nearer £20,000 rather than £2,000 mentioned!
Just for clarity the tie bars are not supporting the rear of the roof structure, they are there to stop the front of the canopy rotating and crashing into the terraces.
Regards
Back to top
 Alert Moderators
Norcon
from United Kingdom
Thanked: 193 times
PostPosted: Wed Sep 29, 2010 10:18 pm Reply with quote
Just an update. Jobs nearing completion now. These were a couple of snap shots I took a while back....
Back to top
 Alert Moderators
geraint
from United Kingdom
Thanked: 24 times
PostPosted: Thu Sep 30, 2010 7:40 pm Reply with quote
alittlerespect wrote:
Hi
Not wishing to cause any offence, but £2k sounds a ridiculously low amount of money to cover the reinstatement works.
I assume that in order to guarantee the integrity of the structure that the whole of the affected structure would have to be taken back to 'ground zero' and be rebuilt, rather than simply replacing a section of one or two columns?
As an aside I would like to mention that insofar as this discussion forum is concerned I am only making impartial comments and not providing unsolicited advice in any shape, manner, or form on what should or should not be done, and for these reasons the reader should place no reliance or relevance upon the comments that I make.
Regards
surely that cannot be a get out clause on a forum.... icon_lol.gif icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 2 of 2
Jump to:
Bathroom Ventilation / Mould / Dampness 16 300 Wed Dec 28, 2011 2:03 pm
Mould Problem in home 4 80 Tue Jan 10, 2012 12:37 pm
mould on furniture but not on walls??!!! 4 100 Wed Feb 01, 2012 9:43 pm
Mould on ceiling / walls/ window frames 2 80 Wed Feb 29, 2012 11:59 am
black mould on wall behind wardrobe, advice please 8 1260 Sun Nov 13, 2011 10:56 am
DIYnot
