DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Consumer Unit
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
  View previous topic :: View next topic
Author Message
hoteldave
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 22, 2005 9:01 pm    Post Subject:
Consumer Unit
Reply with quote Thanks
Hi, I am exchanging my consumer unit for a more modern 12 way split load. My only problem is where to put the \\\"busbar\\\". Do I insert into all the fuses or just do the RCB ones.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Mar 22, 2005 9:28 pm    Post Subject:
How will you test it?
how will you get it certificated?
how do you know what you think is right is right?
I am sorry but if you have to ask that, i stongly recomend you call an electrician
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Mar 22, 2005 9:43 pm    Post Subject:
I'd recommend leaving it off altogether, as a safety precaution.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 22, 2005 11:18 pm    Post Subject:
without seeing it, be aware that the internals of different models of CU differ. The makers in structions are definitive, but in a split load box I'd expect to see two short busses, one linking all the non-RCD stuff to the main switch, and one linking the RCD protected stuff to the RCD.
BUT, I'd expect you to check this before starting the job, and consult with either the makers, or an electrician familiar with that model.
And, as others have noted, you should be checking the wiring you are connecting in to it , for earth continuity and insulation resistance at least, and ideally ring main integrity as applicable too.
regards M.
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
PostPosted: Wed Mar 23, 2005 3:26 am    Post Subject:
Changing CU
If your unsure dont touch it.
You may also require earthing & tails to be upgraded. Do the right thing call the sparks. The split load CU are normally complete and not a jigsaw puzzle, also busbar should be covered for protection. Sounds like u might have been sold a duffer
Back to top
 Alert Moderators
delmel
from United Kingdom
Thanked: 0 times
Changing CU
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Mar 23, 2005 9:54 pm    Post Subject:
Re: Changing CU
Or an MK, and all the bits have fallen out....
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Split load consumer unit in garage 26 1320 Sat Nov 10, 2007 12:31 pm
WYLEX CONSUMER UNIT 7 520 Sun Nov 11, 2007 6:54 pm
Consumer unit mounting location 4 600 Sat Nov 17, 2007 4:23 pm
Replacing an RCD in a MK Consumer Unit 8 600 Wed Nov 07, 2007 1:20 pm
Garage Consumer Unit Supply 3 580 Mon Nov 05, 2007 3:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
