DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Renault Trafic Won't Start
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
Gavin10
from United Kingdom
PostPosted: Fri Jul 02, 2010 4:17 pm Reply with quote
Hi all,had this van 7 year's not one problem.
Today switch ignition on,red engine warning light come's on, try to start engine won't start then this warning light start's flashing. Any idea's please, thank's Gavin
Back to top
 Alert Moderators
aquariusxi
from United Kingdom
PostPosted: Sun Jul 04, 2010 7:59 am Reply with quote
Had a the same problem on a Y reg (2000) model turned out to be the immobiliser was charged 132 + vat buy Renault to repair it
Back to top
 Alert Moderators
Luckyphil
from United Kingdom
Thanked: 12 times
PostPosted: Thu Jul 08, 2010 7:45 pm Reply with quote
Hello Mate . just seen your post I have a 03 Plate Trafic (55k) had the same Problem , got RAC out to sort , couldnt get the Diagnostics to hook up with his Lappy , so I got a towin , It turned out that 2 Sensors had gone down , 1 on the Crankshaft and 1 on the Camshaft (?) , basically they tell the ECU that the Engine is turning , so send Fuel to the Injectors etc
Cost 55 each plus about 100 for diagnostic check
Been ok since about 15k later
Lucky
Back to top
 Alert Moderators
craigwalkerltd
from United Kingdom
PostPosted: Sat Jan 29, 2011 5:07 pm Reply with quote
hi, does anyone have the resistance readings for the cam and crank sensor too see if they have or are failing??
Cheers
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Mon Jan 31, 2011 12:23 pm Reply with quote
If it's the red 'dot' in the middle of the dash that's flashing or staying on, it's not going to be a problem with your crank or cam sensors, it's an immobiliser fault. Check all your fuses, then lightly scrape the key on the ground to earth out any static build up in the key's electronics. Switch on the ignition, and leave it on for about 15 minutes, or until the light goes out. It should then start. Have you tried it with another key ??
Back to top
The following user says thank you to jetex for this useful post:
craigwalkerltd (31 Jan 2011)
 Alert Moderators
craigwalkerltd
from United Kingdom
PostPosted: Mon Jan 31, 2011 2:09 pm Reply with quote
Hi, thanks for your reply.
Red dot on dash isn't staying on!
I have only 1 key for it since i purchased it 2 years ago!
It's running today fine!! Don't understand it, it's been standing for two days and now it's fine, but it's done this before????
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Mon Jan 31, 2011 11:55 pm Reply with quote
I would get another key cut and programmed, because if you lose the one you have, you will be in big trouble. They are expensive, possibly around the 100 mark. With regard to your immobiliser problem, fingers crossed eh ???
Back to top
 Alert Moderators
craigwalkerltd
from United Kingdom
PostPosted: Tue Feb 01, 2011 12:14 am Reply with quote
i will get a key sorted icon_wink.gif lol
It wouldn't start again this evening, i can hear 3 clicks when i turn ignition on coming from the diesel tank??? pump or relay you think ????
turned ignition on and off a few times then started! yeehhhhh... lol
Back to top
 Alert Moderators
tazman
from United Kingdom
PostPosted: Wed Feb 09, 2011 7:53 pm Reply with quote
Hi, Have had a beat up W reg Movano 2800 td for a couple of years and have only had one key for it, one thst doesn't have any buttons on it. Any way a couple of days ago it refused to start on cranking it with twjh key and in fact the immob warning light becomes solid ie stops flashing.
Am sorry to have hijacked / revived an old thread but it's only a few days old.
Am in Brum and would ideally like to have the immob bypassed. If any one can point to a reliable bloke in this neck of the woods I'd be very grateful
Back to top
 Alert Moderators
Wizzy2014
from United Kingdom
PostPosted: Sat Sep 06, 2014 5:05 pm Reply with quote
Hi I have 02 trafic and am also having problems. Do you poss know where the crank sensor is as I have spent 6 hours trying to find. Thanks wayne
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2632 times
PostPosted: Sat Sep 06, 2014 5:43 pm Reply with quote
Typically, the sensor is on the gearbox bell housing, pointing towards the flywheel.
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Sat Sep 06, 2014 9:46 pm Reply with quote
It's not possible to by-pass the immobiliser system without a major rewire. However, it is possible to plug a diagnostic type laptop into some vehicles which will disable the immobiliser circuits. Not sure if your Movano of Trafic is suitable for this. You would have to ask an expert locksmith who had this type of equipment.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
renault trafic 4 660 Thu Apr 23, 2009 6:31 pm
2004 renault trafic abs problem,abs and serv lights on 5 480 Wed Sep 21, 2011 7:06 am
Renault trafic alarm problem. 2 2060 Wed Jul 14, 2010 8:25 pm
Renault Trafic van side sensor 2 100 Tue Apr 24, 2012 6:24 pm
Renault Trafic 1.9TDI 2 100 Fri Sep 30, 2011 12:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
