Leaking Salamander pump & hot water
18 Sep 2007
I have a Salamander RSP100 shower pump. For 7 years it has worked fine and nothing has changed in the meantime. I have noticed a slight leak from the hot side which appears to indicate a seal has failed.
The Salamander website suggests a leak could be the result of water too hot ie no more than 65c. When I check the boiler, the thermostat setting has always beeb about 5.5 which I guess is about 80c which I believe is "normal". I don't think I have another way of controlling the temperature of the stored water in the cylinder. So question 1 ... does this mean the stored water will be around 80c ?? or will it be something lower ?? (if I had a thermometer handy I guess I could test it at a tap.
Question 2 ... is it worth messing with a Salamander pump 7 years old, or should I go for a new one ?
OK - It did not take much for me to spot the temerature control set to 60-65c stuck right on the front of the cylinder. Not something I usually take any notice of. So the only other question is about whether it iw worth fixing the leaking pump - assuming I can get a new seal or O ring, or whatever it needs .....
Any thoughts ?
The reason why one should not be storing water at a temp above 65 degs c is because the pump can cause the water to boil , water will boill at 100 degs C at atmospheric pressure , imcrease atmospheris pressure & the boiling point temp increases , decrease atmospheric pressure & the boiling point lowers , the inlet of a shower pump has a negative pressure ( sucks) hence the reason for Salamanders 65 deg stored hot water advice !!
Thanks to both.
I have already emailed Salamander about parts and am waiting to hear. In the meantime I was wondering if anyone would say that as it is 7 years old then don't bother trying to fix it. That has not happened so I will go ahead.
The pump sucking is interesting.
Another reason to avoid water too hot is apparently that the plastic part can warp thereby causing leaks.
Anyway, I just have a slight seeping, white deposit on the joint and signs of a damp patch where it is standing.
I hope to fix it and keep it running for year to come. I will let you know what actually happens ... (originally I spoke to Salamander on the phone and they seemed more interested in selling me another pump than checking whether they had the parts ...) :eek:
Salamanders aren't too forgiving of minor installation deficiencies, and are inclined to overheat/distort/leak.
Usual culprit is the inlet pipework being too restrictive.
I'd recommend you get hold of an old-style feed and expansion (heating) tank ( a few pounds) and cut round it a few inches up and use that as a tray for the pump to sit in, so any leaks are contained.
For that "boiling" thing, do a search on "cavitation".
Salamander did not call me back despite promises, so I called them again today. It was confirmed to me that they do not keep spares for pumps manufactured before 2006 ! So they try to extract more money from customers by persuading them to buy new pumps.
I have just spoken to Stuart Turner - they support pumps over 20 years old - that is what I expect.
I currently have a Salamander RSP 100 twin - 3 bar pump
If I changed to Stuart Turner, the equivalent would be a Monsoon Standard 3 bar Twin. Any thoughts on this particular pump ? How do they compare ? Is it noisier than my Salamander ?
Any information gratefully received
After complaining to Salamander, it appears that the do have the spares I need after all !
They have sent me a set (large O rings, a couple of clips and a spring thing) for each end - complete with instructions.
Apparently, the 2 separate people at Salamander I had spoken to previously "had been mis-informed"...
