Residue after emptying cold water tank.
13 Feb 2010
Glasgow
This is a house i know very little about other than it is 10 years old.
Switched off cold water and drained the cold water tank in loft. When I did what i had to do I then switched on water again.
I filled the bath, there was a lot(relative i guess) of sediment collecting at the bottom of bath, small dark/brown bits of residue. After I ran the bath (with cold water) for a third time the residue had almost gone.
Looked in tanks of toilets and noticed there was a lot of back sediment at the bottom, but the water flushes clear.
Is this a problem?
Is this water drinkable?
Should I have the system checked by a plumber?
what would he say?
Water that has been supplied by a roof tank is not potable (i.e. Not Drinkable) after draining it is not common for sediment and c**p to be stirred up during refilling, and as you have found things quickly settle down BUT DON'T DRINK ANYTHING OTHER THAN WATER FROM THE RISING MAIN!! :wink:
OR delete "not" :idea: is that C-rap as in the colloquial , or the actual :shock: What would the plumber say :?: Sucks air in through teeth - "that`s going to be expensive , Guv " :wink:
