Greetings.
Both CH and DHW work on the Radiant RSF24 combi
However, on DHW only-- with CH off, the CH pipes are getting hot and DHW flow seems a bit low.
After checking the forums here, my best guess is the diverter valve is not working [jammed in mid position?].
I've tried moving the valve man/auto lever and dont hear the usual "whirring".
I've found the whole part here.
RADIANT 3-WAY DIVERTOR VALVE V4044C 1353 96001LA
so my questions are;
is the diverter valve faulty?
how do I test to see if its the valve or the head/motor that has failed?
can I replace just the motor on this valve, and if so what's the part number?
**edit to ad, just found the motor part number 40002737-002, but I can only find motor part # 40002737-003 -- is this a direct replacement?
can I replace just the power head?
is there a substitute valve?
any help/advice much appreciated
thanks!
thanks!
