Cannon Chesterfield display Problem
15 Jul 2010
We have had our Cannon for just under 2 years and it works fine except that display keeps flickering all the time.
Has anyone seen the problem before and know how to solve it.
Thanks for any help
Flickering displays are usually down to power supply/regulation failure.
It could be a bad solder joint or connection but usually it requires a new PCB.
Thanks for the speedy reply. I take it that as long as we don't need the timer there is no problem letting it fail?
Or is it possible to get a replacement and do the job my self?
Once again thanks.
It is possible to get the timer and replace it yourself (they can be pricey).
As your oven is less than two years old even though it is outside the one year manufacturers warrenty you may have some recourse under the EU fit for purpose or UK consumer goods act (depends on how much you paid, whether new, display model etc, you may be able to claim all or part of repair. We fitted a PCB to a 3 year old sharp combi oven (no display), the lady complained to sharp saying that in her opinion the display should last for at least 5 years, they sent her a new PCB)
Thanks for that I will get onto Cannon and push the point. I have also checked my paper work and it looks like I registered for a 5 year parts warrenty.
Thanks again
But you will have to pay labour charge about £100 parts are free
