DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
MCB and kitchens
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
jonnybhoy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 27, 2005 7:00 pm    Post Subject:
MCB and kitchens
Reply with quote Thanks
This is my first post- great site hope I can get some advice....
I live in a two bedroom flat with one ring main circuit(30 amp fuse at consumer unit) that till recently had an electric cooker running off it, there is thankfully a seperate fuse for the shower.
I am upgrading the kitchen and as such would like to protect the circuit with a MCB converter in the CU.
I have removed the cooker and will have it replaced by a single electric oven and gas hob.
I replaced a single socket(ring main) with a double and have run a spur off this that will power the fridge/freezer. I have replaced the cable that went from the switch for the cooker with 2.5mm twin and earth connected to a twin surface box in a base unit that will power the single oven and gas hob.
Bearing in mind that in the living room I have TV, seperates hifi, 2x PCs,one monitor, video, cable box, xbox what should I replace the existing 30amp fuse with I had originally bought a 16amp MCB now I'm thinking that I should get a bigger one, also have I done anything daft?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
felix
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 27, 2005 7:08 pm    Post Subject:
It's not dangerous to run your ring circuit from a 16 amp breaker but you'll be forever resetting the thing when the oven's on! Get a 32 amp one instead. Yes, I know the old fuse was only 30 amps but all our existing cables mysteriously got better!
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 27, 2005 10:37 pm    Post Subject:
As you have already realised it would probably be better to split the supply and have a separate one for the cooker. You have already made things better by having a gas hob instead of an electric one so i guess if it worked ok before it should still do so. 32A breakers replace 30A fuses because breakers disconnect the supply faster than a fuse would melt.
__________________
His vorpal blade went snicker-snack
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sun Mar 27, 2005 11:15 pm    Post Subject:
no 32A breakers replace 30A fuses because of european harmonisation.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
dimmers in kitchens 10 420 Wed Jul 11, 2007 8:19 pm
Lights in Kitchens 3 480 Sat Jul 14, 2007 9:48 pm
Building Regs. for wiring of extractor fans in KITCHENS 5 360 Mon Apr 13, 2009 8:10 am
Sockets in kitchens 4 420 Thu Jul 05, 2007 10:14 am
Cables in kitchens 19 880 Mon Jul 02, 2007 10:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
