shelving unit / wall lights x3 / dimmer and plug socket?!
25 Jul 2010
Lancashire
I have made a floor standing shelving unit from MDF and want to add 2x lights on a dimmer and connect as a lamp from the mains.
The wall lights are 40w halogen wall lights and will be permanently fixed to the shelving unit.
The dimmer is a 250w push rotary dimmer 1g switch and will be fixed to the back of the unit.
I want to power the lights from a wall socket using a 3 pin plug
Could you please help me with the wiring? The dimmer is in a plastic wall mounted box and I will have to add a connecting block for the earths as it doesn't have a corner terminal as metal boxes have.
I will need to earth the wall lights as they are part metal bodied.
You will need a connecting block for the neutrals, as well.
Inside the dimmer box you will need:
Cable from wall lights: brown to dimmer L1, blue to term block1 (neutral), earth conductor - sleeved green/yellow - to term block2
Cable from wall plug (make sure it's got a 3amp fuse): brown to dimmer terminal C; blue to term block1 (neutral), earth conductor - sleeved - to term block2
That's it.
Thats great thanks, one last question: -
Do i connect the wall lights in series i.e. one cable from dimmer to wall light one, then from wall light one to wall light two (blue to blue, brown to brown earth to earth)or do I run individual cables from each wall light to the dimmer?
thanks
If theres only two lights either way whatevers neatest, theres not always room for two wires in some fittings.
Your not actually connecting in series though, just looping light to light.
Thanks for the help
next weekend we should have lights!
(would have used the thanks button but apparently I am not logged in...)
