DIYnot
Local | Network
   DIYnot > Forums
Local | Network
vokera compact he boiler problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
doobs76
from United Kingdom
PostPosted: Sat Jul 31, 2010 11:54 am Reply with quote
I have the above boiler and at present have no hot water or heating. The boiler itself fires up when hot tap is run and when heating is switched on but no heat or hot water follows. The light flashes green every 5 secs or so.
Can anyone offer any advice/ solutions?
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1286 times
PostPosted: Sat Jul 31, 2010 12:11 pm Reply with quote
The heat has to be going somewhere, are the rads heating up when you run the hot tap ? are you sure its actually firing up?
Back to top
 Alert Moderators
doobs76
from United Kingdom
PostPosted: Sat Jul 31, 2010 12:22 pm Reply with quote
It sounds as if it's firing up...as in it's the same noise when it did work.
Excuse my ignorance but I know nothing about boilers icon_redface.gif and as a single parent am dreading the cost of getting someone in to fix it!!
The manual is no help either...
Thanks for you reply..
Back to top
 Alert Moderators
manofgas
from United Kingdom
Thanked: 4 times
PostPosted: Sat Jul 31, 2010 12:37 pm Reply with quote
Boiler has not fired up if green light is flashing, that it at stand by mode.
Run your hot tap and watch the light on the boiler. If the boiler goes to a solid green light the boiler has fired . If not switch off the tap and turn on all your heating controls to on, again watch the light on the boiler.If it again stays with a flashing green light it has not fired up.
If the above is what is happening there is a fault on the boiler and it is not going to the ignition stage for what ever reason. Most likely that there is a small blockage in the flue system, this would have to be looked at by a gas safe engineer.
If you can get a local company to call out and this is the fault the cost should not be to great 50 - 75 fora service and repair.
Back to top
 Alert Moderators
doobs76
from United Kingdom
PostPosted: Sat Jul 31, 2010 12:41 pm Reply with quote
It's exactly as you have described. Flashing green constantly.
I'll contact someone to have a look.
Back to top
 Alert Moderators
manofgas
from United Kingdom
Thanked: 4 times
PostPosted: Sat Jul 31, 2010 1:42 pm Reply with quote
let me know how you get on!
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 845 times
PostPosted: Sun Aug 01, 2010 5:59 am Reply with quote
Perhaps following addition might be appropriate- green light flashing every 5 seconds, boiler has no demand. on demand light flashes rapidly every half second to go solid when burner on.
Back to top
 Alert Moderators
manofgas
from United Kingdom
Thanked: 4 times
PostPosted: Sun Aug 01, 2010 2:27 pm Reply with quote
correct but unit would go to a solid red if a failed ignition has occured, not reaching that point.
Back to top
 Alert Moderators
adam1986
from United Kingdom
PostPosted: Sun Aug 22, 2010 9:38 pm Reply with quote
I am experiencing the same exact problem, what did the guy you got in say and how was it fixed? Any help would be great.
Back to top
 Alert Moderators
mevans1223
from United Kingdom
Thanked: 2 times
PostPosted: Fri Dec 03, 2010 4:01 pm Reply with quote
I had a problem with my boiler, the green light kept flashing every 0.5 seconds then after a while went a solid red, I was told that I had a problem with the condensation pipe. Which on my boiler is the grey tube that goes into the white one at the bottom right corner under the boiler, i had to disconnect the pipe ad drain the water, then the boiler worked properly as a sold green light. I had this problem due to the cold weather, not sure if this would be a problem in august.
Back to top
The following 2 users say thank you to mevans1223 for this useful post:
boilerdude25 (18 Dec 2010), dogon1 (8 Dec 2010)
 Alert Moderators
boilerdude25
from United Kingdom
PostPosted: Sat Dec 18, 2010 11:58 pm Reply with quote
many thanks to mevans1223 for this post. My boiler has been locking out in the recent very cold weather and exhibiting the same symptoms. I checked the condenser trap as suggested and it was full of water, which was easily drained by removing the small clear tube at the top of the trap. Once drained, the boiler fired right away. I'm unsure why the condenser trap is filling up but i suspect the drain pipe is freezing up or its blocked and not allowing condensation to drain out of the system icon_smile.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3559 times
PostPosted: Sun Dec 19, 2010 12:50 am Reply with quote
There are perhaps 100,000 boilers all over the country with frozen condensate pipes. Most owners learnt about this last year!
Its often possible to disconnect the condensate tube indoors and put it inot a bucket until the weather gets a bit warmer. However, thats technically incorrect as there is a water trap between the boiler and the outside in only some boilers and in any case you should not rely on that for safety.
Pouring hot water over the condensate pipe will often unfreeze it.
Tony
Back to top
 Alert Moderators
bluenosedave
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jan 14, 2011 7:32 pm Reply with quote
IF YOU HAVE TO DISCONNECT A CONDENSATE PIPE INDOORS DUE TO FROZEN CONDI PIPE OR BLOCKED SAME.IT IS ADVISABLE TO FIT A CO ALARM IN THE VACINITY OF THE SPLIT CONDI PIPE,BELTS AND BRACES REALLY. icon_rolleyes.gif
Back to top
 Alert Moderators
bluenosedave
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jan 14, 2011 7:45 pm Reply with quote
I MUST ADD THE REASON FOR THE co ALARM IS IN CASE THE CONDI TRAP RUNS DRY [FAT CHANCE ] THOUGH SOME BOILERS are unpredictable and in practice it could happen in which case poc.s could escape into the surrounding area.
Back to top
 Alert Moderators
Ray84
from United Kingdom
Thanked: 31 times
PostPosted: Sat Jan 15, 2011 1:49 am Reply with quote
water seals big enough on a vokera compact to say it wont run empty (75mm min)
therefore a co alarm for disconnecting the condensate pipes not really required and shouldnt scare you to do so
Ray
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera Compact 24 - Problems 3 3400 Sun Oct 22, 2006 8:31 am
Vokera Compact 29HE CH problems. 4 1940 Sun Dec 09, 2012 1:36 pm
vokera compact 25 pressure problems 4 100 Fri Dec 26, 2014 11:23 am
Vokera Compact 28 red light problems 4 4060 Tue Mar 22, 2011 7:57 pm
Vokera Compact Problems 8 900 Tue Aug 28, 2007 11:05 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
