Extractor Fan advice needed
20 Apr 2009
Norfolk
HI,
The extractor fan in my bathroom stopped working ages ago, and i removed it thinking id get a new one... that was years ago and i've forgotten the make/model so I can't simply buy the same one again.
it was a 240v in-line fan (4") and had a timer on it. it looked similar to this one on ebay
http://cgi.ebay.co.uk/IN-LINE-EXTRA...ling_Air&var=640004909238&hash=item950343e8b6
Could someone who knows about these things recommend me a make/model that they think is good/reliable/quiet etc. I don't want to 'go cheap' on ebay and regret it when I receive some sub-par fan.
and my second question is this...
my shower room has no windows, and the door fits pretty snugly. for the extractor fan to work effectively, do I need some sort of trickle vent in the door to allow air flow in? or am I over complicating matters?
thanks
You could go cheap and replace it again in a year or two. The better quality makes such as vent axia should last longer but will cost more. They will be quieter on a plaster and brick wall than on a dry lined wall or plasterboard ceiling.
If your door seal is that good then you will need some form of make up air to allow the extractor fan to work at it's best.
thanks for the advice.
after seeing the price difference between the cheapos on ebay and vent axia, i'm going to risk the ebay one.
cheer
Shave the bottom half-inch off your bathroom door.
If there's no way for air to get in, even the most powerful fan you can find won't do much.
thanks for the advice but I'm going to go cheap on eBay and buy a sub-par fan.
:roll: :roll: :roll:
hah, yes I see what that looks like.
the reply i got suggested that even a cheap fan would last a couple of years. 2 years for £10 isn't that bad in my mind.
the vent axias look like they are over £70. that's a big difference.
